Help Add to Home Screen
Dicky
Member
Not sure if i got this in the right place or this should go to the support/troubleshooting portion.
In the midst of customizing my phone I'm trying to make a Short Cut to "Add to Home Screen" but I can't figure it out.
I'm using FolderOrganizerLite to do this btw...and I also have Any Cut and am using LauncherPro.
I would also like a customized icon with this shortcut :)
Any help to point me in the right direction would be very much appreciated.
Why do you need a shortcut? Just long press on a space anywhere on your home screen and the "Add to Home" menu will pop up.
:o I never knew you could do that, i always thought i had to press Menu and then Add.
Gosh!!! Silly me, thanks a bunch.
