Help Adding or Deleting Home screens
Google seems to think its neat to have fixed # of home screens instead of dynamically creating them as the user needs them. Basically every launcher from the User created to Manufactures add this but Google doesn't.
One of my pet peeves.
I'm wondering; if you replace the stock launcher, how would you add widgets if the launcher hasn't been updated/optimized for ICS? Because the stock launcher has the widgets in the app tray and you can't access them just by long pressing on the background anymore.
I find this more than rediculous. I have an asus tf101 running ICS and the fact that I can't change my homescreens/desktops is extreamly frustrating. I can understand them keeping the "max" limit at 5 but why not let you take any away? Heck, I don't even want to take any away. I just want to rearrange them! The problem is I have NO room on my desktops anymore so can't "rearrange". I have the entire right-most desktop (5) full of shortcuts (for games) and want to move them to the left-most (1, which is apps) to make things a little more "logically" organized (2 is all games as well) and I am hating the fact that I will have to delete everything from the left one and one by one move every shortcut from the right one to the left, then add the ones I deleted from the left to the right again. Simply rediculous... smh. Very poor testing I would say. Anyone who played with the OS long enough would see the problem in not being able to rearrange them at the least.
Select a homescreen, delete one shortcut and replace it with a folder. Put all of the icons from that homescreen into the folder. Do the same with your other homescreen to be moved.
Once you have your homescreens packed and ready to move, relocate the folders to their new homescreen and reverse the process.
Sounds easier than recreating all of your shortcuts.
If you don't have root access, you bring up a list of Widgets either via the app drawer or via long press on he screen which gives you the option to add shortcut, app, widget etc. And for widgets you get a list with no preview.
If you have root access you can usually do it two ways:
Long press on screen as above
Normal way through app drawer with previews
I use Nova launcher but I assume its the same for most other ICS launchers.
I use nova launcher which is basically the ICS layout. It works just like the stock launcher except it has a few extra tweaks that I really enjoy. Like number of homepages and getting rid of the Google search bar at the top. Also apex launcher works the same as well and they both are basically just enhanced ICS launchers.
I tried to add a widget to a page that wouldnt fit and it asked if i wanted to add anogher screen which it did. I cant remove it though
Edit: in ics just pinch your fingers together to edit your homescreens
