Most of the time you camera app saves photos in the DCIM folder but it can be different for different camera apps and most camera apps also allow you to specify a different folder. So the bottom line is you will need to search. I would suggest that you take a picture and then save it with a name you will remember. Then go into the file manager on the phone and search for it so you can find out where the app is saving photos. You could also go into the camera app and see if you can figure our where it is set to save photos to.
