Adding/Removing apps to Multi Window
xfengx
Hi everyone,
Does anyone here know how to add/remove specific apps to the multi window without using apps which require the phone to be rooted?
Cause currently I am unable to remove apps I dont want from the multi window and also cant add specific apps which I want to be on the multi window.
I cannot really answer your question but I thought it may be worth pointing out that very few apps are actually capable of running multi-window. You cannot just do this with any old app; you are pretty much stuck with the ones in the existing list.
Thanks for ur reply.Well,actually there is an app that can support the adding/removing ANY app from the multi window which they claim to.But its only applicable to rooted phone which I have tried before but couldnt root my phone.
That is the reason why I am looking for other alternatives of apps that can perform the task without rooting my phone.
