"1 Press [ ] → Add or tap and hold the empty area on the
idle screen.
2 Select the item category → an item:
●● Widgets: Add widgets to the idle screen.
●● Shortcuts: Add shortcuts to items, such as applications,
bookmarks, and contacts.
●● Folders: Create a new folder or add folders for your
contacts.
●● Wallpapers: Set a background image."
Basically it's the same as adding a widget to the Home screen.
Hope this helps.
(This only works so long as you have already created the bookmark in your stock browser bookmarks... Menu > More > Add bookmark)
No worries mate!
Its a pity if thats the only size bookmark you can have. The homescreen would look much cleaner if they were the same size as standard icons.
