freeperjim
New owner (3 days) of One-X+ and really love it...but one question and one comment:
1. ATT rep told me OK to start using immediately. Alas, I discovered this website and learned the battery should be charged completely before using. Sigh...
2. Adding widgets is becoming quite the challenge. I can add an app from Google Play & add the widget to a homepage. But when I touch the widget, I get error message,
Battery Solo widget:
"You started program with launch icon. Do NOT use the progrm icon! Install the widget!
Data Counter widget:
To use this widget you should go to home screen and add it either by long clicking on an empty spot on your wallpaper (or by pressing Menu aand then clicking Add) and select Data Counter.
Although i have successfully added the widgets to my homepage, is there a secret handshake to get them functioning?
Thanks in advance, y'all!
Jim
Jim
