PrinceCorwin
Android Expert
Anyone know from where to download adfree android?
Google is your friend :]
https://www.google.com/search?q=adf...e.0.57j60j0l2.4945j0&sourceid=chrome&ie=UTF-8
taken from the http://androidforums.com/introductions/704-site-rules-guidelines.html#post3504Phases said:Also while the search feature on forums is great, and hopefully will be utilized - if someone comes here and asks a question, either answer it or don't. If you're going to suggest the search feature, be polite about it. Nothing irks me more than when I go to a forum, (and use the search!), then ask a question because I want some one-on-one with my problem, and get a simple "Use the search." reply. Suggesting it is encouraged, but don't withhold the answer because they don't.
