adjusting live wallpaper
hi i recently downloaded a live wallpaper but the picture itself is too large for my screen. is there any way i can adjust the pic so that it fits within the screen?
Thanks!
Thanks!
I'm afraid that's very much within the live wallpaper app itself. If it does't come with its own setting to control image, then you can't do anything about it.
Contact the developer perhaps ?
cheers
Seba
Ive never had one not fit tbh. Maybe just unlucky with that one.
In the apps comments on play store, u can tap "see all" then select "from this device model only" to see if other s3 users have the same problem :thumbup:
