Root admire roms
i have a samsung admire it is through carolina west wireless. i have clockwork mod installed im looking for a rom that will work for this carrier. thanks in advance
how do i do that ive tried apn backup and restore and apn manager. i can acess the play store youtube but no browser will work
i can access the play store and download anything but my browser wont load and i can get mms and send them but the net browser wont work
ok how do i get to the hidden menu
the easy way is to add a shortcut to your home screen ( press and hold the screen in an empty area), and under select shortcut choose activities. Then scroll down to com.android.hiddenmenu, touch it and scroll down a little until you see browser settings and choose that and then ok. Now when you choose it on the home screen you should see proxy settings. if you change it to match your service provider you should get your browser to work
thanks for all the help guys
ok ive been messing around and still no browser. but i dont care about that any more. how can i get CWM 5.0.2.8 on my admire i have CWM 5.0.2.7 on it thanks in advance
its a stock carolina west wireless one when i load monster 5.3 i think it loads fine but when i restore my backup that i made on CWM 5.0.2.8 it goes to a sliver small android and wont go any futher
Did you make the backup with 5.0.2.8 or 5.0.2.7? What filesystem is the backup, when you look in the backup folder does it say system.rfs, data.rfs, etc.?
