Help Admire will not send pic message
Country Dad
Ok, Im using Go sms, but I am having issue sending picture message. What is going on, is there something I can do to fix this?
What kind of problem are you having? I just sent myself a pic and I had no problem getting it.
umm i use go sms before i did not have this problem check and see if there is a update for go sms on the android market try resetting your phone (turning it off then on again)
if that does not work try the regular messaging app and see if that works if that does not work try sending different file pictures or if you try to send a picture from your camera on your phone i am just blank sorry nothing i can do anymore try going to a metro pcs store and see if they can fix most likely no but you can get lucky if they know about android phones like me :)
OK ok i will help try switching to the regular android messaging app i know go sms is the best but if something does not work you got to switch back to the regular (stock app) sadly :(
i get that problem on metro pcs from time to time i place a call to whatever number even voice mail for some reason when i do that it sends the picture right after i hang up try it let me know if it works for u too
