what you're talking about are the two chinas next to the earpiece one is a light sensor, the other (maybe)is a proximity sensor.so ones for the auto screen brightness if you have that enabled via the power control widget
) lawlsDoesn't matter what you saw in the system files.... look at the phone, there is no front facing camera!!I'm pretty sure it. Does have a front cam. I got down in the system files and seen some thing. Im not sure a what I was looking at but this id what I saw:
<permissions>
<feature name=''android.hardware.camera.front"/>
</permissons>
and this:
android.hardware.camera.front.xml
android.hardware.camera.autofocus.xml
<permissions>
</permissons>
and this:
So we have 4g to just cause the xmls r there. You should dig deeper and you'll find a bunch of shit burried.
