Root admire wont go past model logo
alexr777
So I installed CWM on to my admire, i flashed admired monster to it last night and it worked for a while but now the phone wont go past the logo that tells you the model of the phone BUT it will go into CWM successfully. Is there anyone than can help me? help will be appreciated.
If you made a back-up format system, data, cache, dalvik and restore.
i made the dreadful mistake of not making a back up
You're in quite the pickle then. Try the ODIN return to stock thread and after that the ODIN CWM thread. That way you can at least get your phone back to stock and with CWM afterwards. Then make sure you make a back-up prior to installing Beast/Monster.
Try re-flashing your ROM
REBOOT
Before you ODIN back, try a factory reset.
REBOOT
If it does the same thing, format the /data in CWM (Mounts and Storage -> format /data)
REBOOT
IF THAT FAILS *** Format everything 3 TIMES /data /cache /system , then do a factory reset, THEN Flash your ROM again.
IF ALL OF THAT FAILS ODIN back to stock :) I ran into the same problem.
