Adobe Flash For LGOSlider?
Tote
Hi, I'm new to the forum and to smartphones in general, having just upgraded from a tracfone to the LG Optimus Slider last week.
So far I've been very happy with it's performance and I've had only minor, easily fixed problems.
However, I seem to be having difficulties finding information on if the LGOSlider supports any form of Adobe Flash.
I DO NOT NEED IT TO SUPPORT GAMES. I don't need it for anything drastic.
I just want it so I can load the small flash files on a webcomic I read on the mspaintadventures dot com site.
I'm an avid fan of Homestuck and some of the updates are flash heavy. I can't load some of it on my phone and this is very disappointing as it updates quite frequently, sometimes seven to eight times in one day.
Is there anything I can do?
Officially your correct, they have got it working though just use Flash 10.2, follow the instructions. If version 10.2 doesn't work download the 10.1 version. :D
I tried both 10.2 and then 10.1 and neither of them worked for me. I did reboot after each install, but couldn't get flash to work. Any ideas?
It's not working for me either, and I did the same. I'm using a Virgin Mobile Optimums Slider with Android 2.3. Dissapointing...
I read that there's a way to root this phone and get it Adobe working, but it's not an easy root with gingerbreak. Lots of people having problems with that as well.
Well then try these (all for the armv6 devices)
Adobe Flash Player 11.1
Adobe Flash Player 10.3
Adobe Flash Player 10.2
Adobe Flash Player 10.1
There are in rar form so extract them and install the .apk inside
From MaiPad Website
Confirmed working on most armv6 from [APP] Official Adobe Flash Player 10.3 Final - For ARMv6 - xda-developers
Also, if these don't work keep searching yourself, there is bound to be one that works. I did the same thing until I found one that worked on my armv6 Optimus V. Try dolphin browser as it's supposed to work best with these versions of flash.
From MaiPad Website
I respect you for putting the time in to promote these apps and assist people in using them, but they just don't work on my LG Optimus Slider from Virgin Mobile.
11.1 & 10.3 returned the message "application not installed" at the end of the install. The 10.3 Final installed but had no effect on the inability of the Dophin HD v7.21 browser to recognize flash.
I can use the Skyfire browser to view some flash pages, but not ones in which flash is delivered through a dedicated pop-up window. That will have to do.
Thank you for your help.
Bill
From MaiPad Website
The 10.3 from this link [APP] Official Adobe Flash Player 10.3 Final - For ARMv6 - xda-developers finally did the trick. Thanks!
