Adobe Flash for MTS - Froyo / 2.2?
rrolff
Looking to install Adobe Flash - but it looks like you need Froyo 2.2 to get Adobe.
Has anyone done this on 2.1? Does anyone have directions for Froyo ?????
Bump - anyone know the ins and outs? There are some Youtube vids - but it seems to depend on the version you currently have (mine has the OTA upgrade)...
I recommend going to xda development section and your question will be answered. Use their site for all development questions if you want answers right this second. Most members here aren't into dev. Quickly though:
-You need root to install
-The so called 2.1 version is not complete and is no better than the preinstalled flashlite our phone already has!
-Even with 2.2 flash will not be perfect as adobe says it needs a minimum 1ghz arm7 processor. Slide does not meet these requirements. Will it work...yes. Will it work well...NO
Question answered...no more need for shameless self bumps;) it's only been a day since first post anyway...give us time to answer.
Go here and follow the instructions, it doesn't need to be rooted. It works but like it says on the page because your missing some codes and the complier from 2.2 its not going to run perfectly.
I've been using it on my MTS and it all depends on how big the flash file is and how much is going on for the performance. Like the above post said, it basically comes down to the processor.
How To: Install Flash 10.1 On Android 2.1 Eclair Devices
Hope this helps
Yeah but we already have flash on the device. There is no difference in performance from that tweaked version of flash 10.1 and the htc flashlite on our phone. The preformance cannot match native flash 10.1 for froyo.
