Help Adobe Flash - lib - Update 11 ??
d2007k
followed youtube vid and installed flash.. works good except now im getting tgat my flash is outdated on some sites .. reporting i only have version 10.. i installed version 11 but i had no new lib files to replace old so i re-used old and works except version still at 10 .... anyone know how to update?
If you go manage apps does it state you have 11.0 or 10.x installed?
Also a heads-up, If it was not already mentioned, flash does not work with Opera mini browser but seems to work with stock metro browser and Dolphin. Just takes forever to load. I think it might have to do with the way Opera compresses data for faster page loads. Just a guess.
says i have 11 installed. So my only conclusion is something in the lib folder that needs to be worked out ..
yeah i found out bout opera .. skyfire works pretty good .. mine doesnt take long at all for the adobe settings to pop up ..
ahh well .. if we can just get some cyanogen id be happy .. few more months (by that time ill have a new phone)
try these in data data directory
like the utube video stated
ps: you'll have to work the permisions and do some file moving
and possably created another data directory
but if your in over you head there is a new flash 11 on market for free
so between the instruction and files you'll be able to fly
pss" disclaimer not responsable for any personal out comes
its your phone ///// be careful.
update: 2/11/12 1040 pm
personally tried this on two admires. Both are fully functioning with flash player 11...
one has 2.3.4 and one has 2.3.6. o/s , No problems with either. all files have been scanned
with eset and malware bytes.this is my experiance that i had the inclinnation to try and
and am only relaying my outcome and results....
If you are not willing to gamble leave your phone alone.
Stay Safe, I have got 2 devices that i have improved upon myself and i feel good about it.
viperdink out!
im not one to just try things .. where did these files come from ?? a working update from ??
the lib files originally posted from youtube were modified to work on this phone ... and when going to the market it displays phone is not compatible for flash .. so you cant download it there.. you have to get apk off net .. which i got latest version and installed but we need new updated lib files made for this phone
