Root Adobe flash player works on samsung prevail!!
All I did was copy it to my sd card . After it was on my sd card I used Root Explorer, went to the app and tapped on it . It gave me the option to install and I did . Works fine now .;)
ok i did that too but haven't tried it what is something good to try on
some people were saying something about a file data/dat/......and is empty and have to move the file into the folder and turn on permissions and stuff like that
EDIT : Tiny Shark needed Flash but doesn't any longer . I installed it like I said earlier and tried it on the old version of TinyShark .Hmm , does Youtube need Flash ?? I'm trying to think of another site that needs Flash . Can't think of any right off .
You don't need to do that with version 10.2 . From what I'm reading , you only need to do that with the newest version of Flash
I know that when I installed and tested it on TinyShark a few months ago , I just installed it straight from my sd card and it worked .
2 bad that you can't test it with TinyShark anymore .
That's not true, if you have a rooted phone with CWM installed there's a few kernels out there that let you OC the Prevail, mine is currently OCd to 900 MHz... :p
Sent from my SPH-M820-BST using Tapatalk 2 Beta-4
LOL , that was posted before we had the OC kernels . :p
Please message me if you can watch Justin tv using your Samsung galaxy prevail because this doesn't let me :/ I NEED TO watch tv because I am always traveling.
Works for me and now I can watch my anime! Of course I need the prevail maxed out at 950mhz to run decently.
I actually have my CM7 running Flash 11 :cool: I can't remember where I found it, but I can upload the apk I'm using if anyone cares for it...
I also would love if you can upload the apk for 11. I could have sworn though I read that only 10 would work on our phones. I think it was one of those adobe threads or the CM7 thread. If you got 11 working then that's awesome! :D
well i posted this on another on another thread but for just so everyone sees it here's a link to a modified adobe flash player that works
[NEW] FLASH PLAYER 10.2 FOR ARMv6 AND ARMv7 (ARM11) ANDROID PHONES - xda-developers
i tried it on
http://androidforums.com/galaxy-prevail-all-things-root/443532-rom-187mod-honeybreadsandwich.html
and it worked pretty good on the youtube desktop version
i believe it should work on any other rom also but i have only tried it on HoneyBreadSandwich RoM
just download and install like any other app and restart your phone ;)
dont forget to hit the thanks button :D
Yeah we know... But thanks for the link, mine is messing up
