Help adobe reader substitute??
donas
Is there an app. that could be used in place of adobe reader to download pdf files? I currently use docs to go, which works fine to read pdf files, but I can't transfer by means of cable or over the air. I use a couple of internet sites for work that state "must use adobe reader to download files".
When I attempt to download a file, I get a message that says download was unsuccessful....it still shows up under downloads but docs to go says the file is damaged and can't open. I am having this problem for any pdf that isn't emailed.
Opening a pdf is not a problem, I can't get them onto the Xoom at all. I can email a small one and save it then open, but I can't download one from the web or using the usb cable. I get a download failed message.
