Adobe's Flash Player 11 being pulled from playstore aug. 15!!
bnb25
Android Expert
Adobe's Flash Player 11 is being pulled from the Playstore on AUG. 15, How will this impact those "me included" that want to use it with custom ROM's that have it uninstalled? will we be able to download it our self's? Is there some place we can get the apk?:dontknow:
I personally think its stupid they are stopping support for it. They must be in Crapples back pocket. It's one of the reason's people buy Android phones.:mad:
I just un installed the newest version for Firefox because the audio skipped every time i moved the mouse. So i re installed version 10 and it works perfect.
the company has
explained that devices which have been
certified to run Flash will still continue to
do so, and updates will be made available
just for those devices. Any devices that
have not been certified to run Flash will be
unable to install or update it from the Play
Store from August 15th.
the company has
some of the Custom ROM's don't have it installed, once its pulled from the playstore you wont be able to install. If you read their entire post. they say on there that it will only be offered through manufactures ROM's not through the playstore, you'll only be able to get updates through the playstore.
I just uploaded mine to my dropbox for whenever I have to start from scratch with my phone I can just access the apk from there =]
Yeah that sucks I think there only gonna stick with PDF only
from what i read, they say "adobe" that most sites now have mobile sites, so no point developing flash for mobile use, and also they want to push adobe air for mobile apps. Personly i hate most mobile sites, they suck and usually really stiff. I hate Html5 all together really
