Help ads by inmobi
Hi there.
I've recently bought my self a Samsung galaxy 6 edge
Having had iphones for years thoughto i would try android but doubting my decision now...
My phone has been taken over by this inmobi ads popping up every minute or so.
I've tried numerous adremoval tools and the "opt-out" on inmobis Web page but nothing seems to help.
Can some one please help me get my phone back ???
Cheers Mike
Ok so neither of that helped...
Would a factory reset help ?
Would rather not if I could help it...
Yeah, if you can't find the browser hijack or the offending app that's probably your only option.
Power down the phone, hold volume down while powering on until the pin request is shown - bottom left side is the Safe Mode button - use that.
Your phone will boot up and only run the stock apps.
If the problem goes away, it's an added app. If you can't find it otherwise, factory data reset is your friend.
Watch what downloads automatically from the Play Store after you go back into setup - chances are you could download it again and be back to where you started.
If you have added any kind or form of performance or battery or task helper, uninstall them ASAP - I mean uninstall them yesterday ok.
^this (sorry I have a habit of '^thising" stuff lately) hope everyone takes it how it's intended? :)
