Help Advanced Calling 1.0
hilmar2k
Android Expert
So now that the VZW G3 supports Advanced Calling 1.0, has anyone successfully used it? Since getting the update, and activating the feature online, my phone no longer accepts calls. It rings, and as soon as I answer the call is disconnected. If I go into settings and turn Advanced Calling off, it works just fine.
I have an opposite problem. I can receive calls just fine. If I try to make the call, they can't understand a word I'm saying...telling me I sound like Charlie Brown. I am so excited for this feature to work!
I should add that the calls that aren't working are NOT Advanced Calling 1.0 calls, but regular cell calls and landline calls. Since almost no one I know has a compatible phone, I haven't even tried an Advanced Calling 1.0 call yet.
So I should not take the update? It started to download on mine. What other things does the update update?
The update is fine. Even enabling the feature one is fine, as long as you turn the feature off in the network settings on the phone.
