abscissaordinate
First let me explain how I use Advanced Task Killer (ATK). I use all the default settings with the exception that Auto Start is off. What I do is, every now and then, I open ATK and kill every app that shows up on the list, including ATK itself.
I've had my Incredible for about a month; I've been doing the exact same thing for about that long as well. However, recently (maybe a week or two, I am not sure), once out of every handful of times when I ask ATK to kill all appls, ATK kills them, but the white background with green "htc" logo shows up for a second or two. (It looks kind of like when the phone first boots up.) Then it goes to my home screen, but it looks dim and fuzzy, like when you turn off your phone where a rectangle pops up in the middle of the screen saying the phone is shutting down while your home screen is dim and fuzzy. Instead of saying the phone is shutting down, however, the rectangle box in the middle says "Loading..." I do not know what it is loading.
My impression is that when I ask ATK to kill all the apps on the list, it somehow kills some "important" ones so then my phone immediately reopens those apps hence the "Loading..." screen. What is puzzling, however, is that it just started doing this recently. I do not think I have made any major changes to my phone in the last few weeks.
I have tried to pay attention to the apps that ATK kills before I kill them; I have not been able to spot any pattern.
Does anyone have the same experience? Or does anyone know what is happening here? As far as I can tell, my phone runs fine, but it is a little bit disconcerting when that "Loading..." screen shows up every now and again.
Thanks!
Tim
Thanks!
Tim
