advanced task killer
gjnmir
I just recently added this task killer. Quite often when I check to see what is running, the mp3 store and voice dialer show up. Neither one have I set up to use on my phone. I don't know if I should even care that they are there, but it I wanted to get rid of them, any suggestions?
It's just one of those things that automatically start up and you can't do anything about them. Put them on the auto kill list and it will kill them when your screen goes off. This is the only way to "fix" that, unless you root and put on a custom rom that has those removed.
i use the startup auditor. I'm not sure if you have to reboot your phone for the changes to take effect, But yea, that should do the trick. It's only 99 cents.
