Hello, I am new to android and Galaxy Note. I have a few questions:
1. I have 16GB on my Note and a 16GB memory card.
What is the best file organization? Should I store everything
in the Note's 16GB memory first before moving to the memory card?
Alternatively, should I install Apps on the internal memory while
music, video, photo files on the memory card?
2. In Kies air, under file explorer, I see /sdcard with subfolders
Android, Application, bluetooth, DCIM, download, Evernote,
external_sd, lookout, LOST.DIR, media, Music, Samsung,
samsungapps, ScreenCapture, ShareViaWifi, usbStorage,
Videomaker.
a) Which directory corresponds to the sd memory card?
b) What is usbStorage?
c) What is the difference between /sdcard and external_sd?
Inside external_sd, there is a LOST.DIR directory.
Thank you.
Videomaker.
Thank you.
