I was just given an EVO 4g that I know nothing about. I have done a factory reset on it. After trying to update it (no success) it is currently at:
Firmware: 2.1-update1
Kernel: 2.6.29-789bf291
Software: 1.47.651.1
I am planning to give it to my son to use as a small tablet, but the version of android is too old to install netflix and a lot of the games that he will want to play. How can I update it?
He will only be using the WiFi and potentially GPS. Are there any specific hacks that you would reccomend for his use (like turning off the cellular radio, etc)?
How can I tell if it has been rooted already?
Thanks for your help!
