Help Advice needed for 'Superpad'
bazzzar
Just after a bit of advice.
I received my 'superpad' this morning and was wondering if it would be possible to install the Tim6a rom.
The specs I have got off the pad are:
MODEL - Android P1001R
VERSION - V2.3 2011-12-07 (001112)
BUILD - FRF85B
It has two TF slots. 512MB ram, 4GB storage.
The main problem I'm having is the wireless dropping (even when I'm not moving) and is forever connecting - dropping - connecting etc etc.
I have also found that whenever I try to connect the pad wirelessly my son's PS3 and wife's laptop drop their wifi signal so could this be a problem with the router, it's all fine until I try to connect the pad!!!
I have tried searching for P1001R but have not come up with any results, so any advice and/or links would be greatly appreciated.
I have also posted these details in another part of this forum so my apologies if you stumble upon it, desperate times means desperate measures :D
45 views and no help? Good job I sent the pile of s**te back, the only thing these pads are good for is a coaster for your dinner plate. Lesson learnt, do tons of research before parting with cash. Only plus side is that I had a 7 day returns warranty.
