ADW Developer
MLSS
Android Expert
Has anyone had any interaction with Tue ADW developers?
I have emailed them 3 times in the last 30 days and have yet to here from them. I would have thought that if someone makes them aware they are having an issue with there launcher they would at least say thanks for the heads up.
If I don't here anything soon I will purchase a different launcher and move on, but I shouldn't have too.
The Nova dev is an android forums member and is active in his G+ beta community. As far as i know Nova Prime has at least all the features of ADW and you can import your ADW layout to it. I think adw is a bit oldschool tbh so if the dev cant be bothered to maintain it, vote with your feet and try something different :beer:
That's what I decided to do as of this morning. I will probably end up with Nova but I will take a few days to decide
It's too bad that with the free version of Nova there's no landscape mode. You have to purchase Prime in order to get that.
You can import your ADW settings into the free version of Nova, BTW.
