Root ADW EX Problem
VoidedSaint
Resident Ninja
has anyone noticed that sometimes a slight error you make will make your dock disappear??? the only thing i can do to get it back is reinstall adw or add a new dock. is there a way to actually show the dock when it disappears?
Are you talking about when you slide up on the dock it disappears?
That's the hidden dockbar. You can actually drag an unlimited number of shortcuts down there. Swipe back down on it to restore the primary dock.
To disable the function, go into setting, ui settings, hidden dockbar, and disable it
im guessin thats what i do, how do you restore it?
Just slide the down where the dock usually is. I'm pretty sure that's the hidden dock that your talking about. Its just another place to add apps. You can turn it off by going to Menu>More>ADW Settings>UI Settings>Hidden Dockbar. Hope that helps.:)
