phantom1969
Thank you very much bbkdhummOn an empty place on your desk:
menu -> add > personnalized shortcut (or something like this, my UI is in french)
Then:
Choose your activity:launcher action -> open/close application menu.
You can change your icon if you want.
Then, just drag your new shortcut to the place you want. That's it !
And you can do the same in order to change your default menu launcher icon
Now my problem is though that the app button doesn't change when I change the theme. Anyone know the solution to this?
