Help Adw Launcher question
kishin14
I know that you can customize what apps you want on the dock bar but is there a way to change the appearance of the icon itself. For example, on launcherpro you can just long press on one of the dock icons to switch it AND change appearance. Is there a way to do is on adw? Thanks.
