chrlswltrs
Extreme Android User
Without uninstalling LP, is there anyway to disable it temporarily/stop it from running? I want to test out ADW but both launchers seem somewhat laggy with both ADW and LP running on top of the stock home launcher.
Other then that, so far I am actually liking ADW better....adding things to the homescreens is slightly buggy IMO, it adds it to the first available spot instead of the location you longpress on, but thats only minor unless you constantly change your homescreens. It does seem a bit smoother, and it seems to transition from the lock screen to the launcher (ADW) faster than it transitions from the lock screen to LP, which reduces some of the remaining lock screen lag seen on 2.2.
You can just remove the stock home if you are rooted, that's what I did
I will play with it for a bit. I am at work and i cant download anything to the computer so I am trying to do it all on the phone side.
