You wan use apps specially designed for this purpose like:
OpenSignalMaps : Have you tried walking all around your house just to get a better signal on your phone? I bet you’ve done that at least once; it’s a little hard to guess where you can get the best signal. Some even climb to the roof of their houses just to get a better signal, but you don’t have to do that when you use OpenSignalMaps. This app will literally show you where you can get a strong signal for your device.
Network Signal Info Network Signal Info is another app that could come in handy if you are very much concerned about the strength of your Wi-Fi or network signal. It won’t make your signal stronger, but it works by helping you determine the real signal strength or Wi-Fi connection. Sometimes the signal bars on your phone can be misleading, so this app gives you a more detailed look, showing you signal strength via 14 signal bars better than the usual five bars that your device gives you.
