Help After Re-activation NO Data over 3g
mikeb40
Data was working fine on old phone number and had no problems with phone at all..because of activation problem had to re activate phone and now no data and no gps phone was working great before all this.. have done factory reset and taken phone back to stock using odin and same problem. have called metropcs about problem and they have re-programmed phone several times using ##626* and all that and still no data.. have re flashed phone SEVERAL times now and still have no data have wiped dalvic cache , cache ,everything I can think of and NO GO.. PLEASE HELP..
First off, welcome to the forums!!
Now lets see if we can get you fixed up. :)
Have you tried to go into the phones settings and try a PRL and Data profile update?
I'm not really well versed on you're phone, so I'm not 100% sure if it has these options or not. On HTC phones this usually fixes this type of bug.
have prl 3028 have tried to use apn changer and wont work on this phone.. can use wifi just fine for internet and GPS but without wifi phone data is no good.. I am at a loss as to how to fix problem have gone back to bone stock using odin and wiped data factory reset so many times I can pretty much do it blindfolded now and just cannot figure out what the problem is... is there possibly something I need to change in QPST??
Have now updated to PRL 3029 and tried again still no data....Somebody please help.. ALSO GPS does not work I am trying to figure out what is going on..
Finally fixed it...Of course without the help of MetroPCS!!!
The fix was actually very simple used QPST and in PPP Config for both um and an still had old phone number for username changed to new number and BLAM-O now have GPS and 3G again.....YAAAAAA ME....
