Root After Rooting
Hotled
ok got my moment flashed with ZE07.
Now I'm looking for a easy to follow thread about how to remove some of the unused Sprint Apps that hog the battery to no end.
Also I was wondering what apps you guys have removed and seen a big battery life improvemant.
I pretty much just need my phone to be able to send/recieve txt,pic mail,web browse and maybe a good calculator. I have a stand alone GPS so I can get rid of all gps stuff.
Thx I have read that a few times.
If you navigate to your /tools/ folder in your SDK folder at the command line, and type "ADB DEVICES" and see your phone, your golden. Don't proceed till you can.
I assume he is saying install the sdk to your pc then attach your phone normaly, then open a command prop from the pc and navigate to the tools folder?
Press and HOLD the CALL, TRACKPAD, and END buttons all at once. Sitting it on a table and using three fingers works well. Continue to hold ALL THREE buttons as the status bar fills, then flashes green. Now you are in "Test Mode"
When I do this it comes up as a Android System Recovery Utility. Is this test mode? Because if I type ADB SHELL I already get the /# sign without typing in:
Code:
cd /system/bin
cat btld_testmode > ../btld_testmode
cat sh >> btld_testmode
cat sh > btld_testmode
Thank you!
Your link was the first time I saw that page and your reference to Zelfies code made it easy!!!
does anyone have a copy of a backup for a moment that they can send me?i bricked mine trying to install a theme. i followed instructions on applying the theme and it said to rename it update.zip.this caused the moment to get the sprint splash screen then nothing.i need the backup to put on my memory stick and restore from it. Odin did not work at all for me this time.thanks
can you get into recovery? go to sdx-developers and download the file in this thread: CL14 Theme Template NOW de-odex'd
put it on your sdcard and load it from recovery...
Odin would work if you put the cl14 with cj05 tar in the formula! Just happened to me and don't have a pc handy yet so I am just going to make the best with the stock theme til then! How did the above post work out for you?
The link you posted above:
This page has been deleted. The deletion log for the page is provided below for reference.
found it. Too much info. Im on overload.
Any Idea where I can find a list of the APK files and thier descriptions? The link to the listing on Wiki is dead.
