Help After trying to update phone keeps restarting !
grigorean
Hello guys !
The problem that I have is that my phone keeps restarting after trying to update to 2.3.5.
The update appeared to be ok but before finishing you just have to select the language and so on.
Well, mine did not managed to reach that... It just keeps restarting and restarting and none of the buttons combinations does work for putting to download mode or reset mode.
I also uploaded a link for the movie, because it has 100mb and could not be uploaded here.
Any ideea guys?
how did you update it?
ODIN? kies?
from what version to which version were you updating to?
remove battery
hold volume key down + home button first then power button
it will bring you to download mode
with odin, from 2.2.1 to 2.3.4 or 2.3.5 i don't remember exact.
i removed the battery and then it worked to enter download mode.
then i updated to stock flash XXJVT and when it had to restart.. it didn't, although odin said everything is passed!
the screen remained black. battery was full and process took 3minutes.
I removed the battery and tryed to enter any mode, download, restart, safe mod, but nothing works. Also, it can not be recognized by pc or by charger.
Nothing happens.
Any ideea?
oh
you must read and research carefully about the roms you were trying to flash especially from froyo to GB
because the most recent GB versions needs XXKPE first before the recent roms available
i hope you are not experiencing a hard brick because only way out would be to samsung service center, unless you could convince them that you were playing/updating with kies then you have no idea what happened afterwards
Hello again guys!
The phone returned from warranty, after 1month and 2 weeks.
It is not working as new, it has a little lag.
I installed Navigon and asphalt and the phone restarted, and entered the restart loop.
I made an update to I9003XXKP9 and i followed all steps but keeps restarting, i updated then to I9003XXKPE but with same problem, and at the end it can not make the hard reset, it turns some errors with red:
"E faild to mount data, no such file or directory."
"E:format_volume: rfs format faild on /dev/block/mmcblk0p3"
"Data wipe failed"
Any ideea?
E:Can't mount / cache / recovery /log. E:Failed to mount /cache (no such file or
directory) E:Failed to mount / efs (no such file or directory) ...
how to fix the prob
Hi all,
Since after from 2.3.6 DDKP2 down to 2.3.6 DDKPE, my night mare started come... my phone restart automatically & wipe off phone settings, msg & contacts... the weird thing is, it never wipe off all application....
Even though I've upgrade to DDKP2, it still having the same problem....
Anyone know this problem & solution pls let me know.
Really looking for solution to solve this problem
