Help After-Update Problem Samsung Reverb
Beezy1978
Hello, Looking for a solution for my newly slow-in-appearing Swype keyboard... That is the only bad thing about the recent update for the Reverb. When I go to text people, it takes a couple seconds for the keyboard to appear/respond. Who do I complain to to get this fixed? ;-)
Is anyone else experiencing this after the latest update?
I know, it may not seem like a huge problem, but it is SO annoying!
Any help appreciated! Ty,
Beez <3
Hi Beezy :hello:
I don't have your phone but this seems to be a common problem with Swype after a new update. Most people have solved it by installing the Swype beta. Give it a try and see if it helps. Or give Swiftkey a try.
I had this slow keyboard problem a little while ago, as well. But it got a little better after the Mobile ID update I got yesterday. Weird...
I've heard that after update bugs and problems can be solved if you reformat and reinstall the firmware with Kies. You can give that a try.
