Help Aggiornamenti sicurezza
M
Member 2183463
Guest
Ciao a tutti, ho una domanda riguardante il mio Xiaomi, nel menù impostazioni-password e sicurezza-privacy, cliccando sulla voce aggiornamento della sicurezza, mi esce un popup con scritto: "è disponibile un aggiornamento software di sistema, ma solo il proprietario può installarlo". Che significa? Telefono originale, no root. Vi allego 1 screenshot x rendere l'idea, grazie a chi sapesse aiutarmi a capire!
Welcome to Android Forums @Popà75. This is an English only site. Please use google translate to post your questions.
I took the liberty to transcribing for you. Thanks for joining and I hope a member can help you.
Transcribed: Hi everyone, I have a question regarding my Xiaomi, in the settings-password and security-privacy menu, by clicking on the security update item, a popup comes out with the writing: "a system software update is available, but only the owner can install it". What does it mean? Original phone, no root. I am attaching 1 screenshot to give you an idea, thanks to anyone who can help me understand!
is your phone up to date? it is saying that there is a security update and that you need to up date the phone to be current security wise.
Of course it's updated, before that menu opened and now it doesn't!
what about google play protect? is that up to date? and what does "before that menu opened and now it doesn't" mean? i know english is not your language, but i do not know what you are trying to say there.
Google play protect is updated, I don't know what's happened, but google does not releases security patches , what can I do?
che dire di Google Play Protect? è aggiornato? e cosa significa "prima che quel menu si aprisse e ora no" significa? so che l'inglese non è la tua lingua, ma non so cosa stai cercando di dire lì.
Hai problemi di comprendonio?
this is an English only site.. i can't read your screenshot.
do you have multiple google accounts setup with google on the phone?
You can use translator like I do :D. I only have 1 google account on the phone, and i don't think it has anything to do with it, thanks.
