I recently updated to 2.1, and have since rooted it and yesterday i tried to install an apps2sd script. when i turned the phone on afterwards it just stuck on the "android" loading screen...
you might need to flash it again. Boot up the phone while holding the volume down button to boot into download mode. you will have to disable the phone as a modem on your PC in the device manager for the PC to connect properly, and reflash with the KDZ software. I had to do this with the same phone
