just air fried some tacos. heated up some corn tortillas, lubed it with some oil, put some meat and cheese in it, loaded them up in the Ninja Foodi and air fried until the tortilla was crispy......so good.
That!so i found that i can get soggy hours old fries crispy and that was to air fry them for 5 minutes or so depending on how soggy and old they were.
No doubt I've done this with takeout meals. No matter what you do they are soggy when they get home.That!
That is a gift to humanity. I must get an Air-Fryer now!
the trick is to heat the tortillas first, otherwise they will break when you fold them. it took me a few tries before i got the technique down. that rack should help out as well. gonna look into getting that.You have piqued my interest my friend. That sounds so very good I immediately ordered some taco racks for my air fryer. Amazon has a four pack of racks for a fifteen and a half bucks... why not give them a try. Thanks for the idea.
They have different ones and packages to choose from. I went with this offerthe trick is to heat the tortillas first, otherwise they will break when you fold them. it took me a few tries before i got the technique down. that rack should help out as well. gonna look into getting that.
do you have a link?
The racks are Prime so I should have them Monday.
I'd be indebted to you for some frozen pizza cooking tips. I went to the store for some dough and there was none to be found, so the fallback plan was frozen pizzas. I tried one in the air fryer and the crust rose perfectly and the cheese and toppings had the ideal browning, but the center of the crust was uncooked.Tomorrow is frozen pizza night at the olbriar ranch. I have two pies that are just beef to cook. I have some sliced pepperoni and and Italian sausage I plan to add as well as a small can of sliced ripe olives.
I have not cooked a self rising crust. All three I've cooked so far were thin and crispy crust. I used the "Pizza" setting and watched the time. The first was way crispy for I cooked it too long. The thin and crispy worked out great when I watched them a bit closer. I have cooked all of them at 375° with the rack inverted in position one.. or the lower position. I put the pies directly on the rack as the book suggested. The first two were Tombstone brand beef and tonight's was DiGirino supreme. I told the wife that I would like to try the rising crust for it's all the rave. I have shied away from them for their extra crust / carbs that my wife doesn't want. I wish I had something to offer.I'd be indebted to you for some frozen pizza cooking tips. I went to the store for some dough and there was none to be found, so the fallback plan was frozen pizzas. I tried one in the air fryer and the crust rose perfectly and the cheese and toppings had the ideal browning, but the center of the crust was uncooked.
I googled air fry frozen pizza bot my results were for personal pizzas, not 12" rising crust ones. Did you use a pan? Air fry? Gimme the details please because I failed.![]()
I haven't tried bacon because I'm afraid of the mess.I bought some bacon to try in the air fryer. Anyone with any experience? Tonight I'm frying some boneless skinless chicken thighs which has become an air fry favorite.
I'm cooking drumsticks in the fryer tonight. Was going to try smoking for an hour then finish off in the fryer, but there is a Nor'Easter going on.I haven't tried bacon because I'm afraid of the mess.I'm cooking drumsticks in the fryer tonight. Was going to try smoking for an hour then finish off in the fryer, but there is a Nor'Easter going on.
Once the weather cooperates I'm doing the same thing.I will gladly be your guinea pig as long as the results are as stellar as the chicken!Thanks for confirming my hunch.Once the weather cooperates I'm doing the same thing.
Based on all that I'll stick to cooking it in the oven or on the Traeger.Air frying bacon is a bit messy. It fried up nice but here are the negatives. 1. There isn't room to fry very many strips at a time. Over lapping the strips is possible but they have to be rotated as well as flipped. One strip on top of another only cooks the strip on top. 2. Bacon by nature renders a lot of grease. I wrapped the pan beneath the basket to catch the grease and prevent it from burning on the pan. This worked great but had to be emptied multiply times while I was cooking to avoid a dangerous spilling amount of hot grease in the pan. 3. The bacon really didn't mess up the inside of the air fryer like I anticipated. There really wasn't that much splatter. There was a lot of moisture release that condensed on the glass door and some on the sides that I had to towel out. 4. Most bacon is cured with a certain amount of sugar. That sugar caramelized on the frying basket and took some effort to scrub out. It stuck on the inside as well as the bottom of the basket. It cleaned up and if that was the only means I had to fry bacon I would not shy away from the cook.
I will say that the bacon was very good. Not greasy and I was able to cook it to the degree that I like without a problem. (just starting to be crispy but not crunchy) Though the air fryer did a great job cooking the bacon, I'm back to using my electric griddle for bacon.
