Plane mode kills all transmitters in the phone, so wifi,bluetooth and mobile network. To use these you have to exit plane mode.Yes, you can still turn on WIFI when Plane mode is on.
I have been successfully using wifi whilst abroad and in airplane mode. When you select airplane mode it will turn off the wifi so you just have to manually turn it back on again.
I've found an app called EasySwitch, a useful widget with all of the switches in one place.
Yep, I tried and WIFI does indeed stwitch on while in plane mode...
RE: the roaming setting, I guess that's a good fail safe, but I would feel nervous relying on it - I just don't trust it, but not sure why!![]()
I think when you initially turn airplane mode on, it disables wifi, but then you can re-enable it. This is true in some builds anyway.
I'll be out of the UK from next Monday and obviously want to ensure I'm not hit with any excessive charges.
I want to be able to receive calls and a messages, and also make calls and send messages. I can access WiFi in my hotel for free, so may do this if I feel like a browse of the internet. What is the best and safest way to set up my phone to ensure I am not hidden with any charges?
Switch of Mobile Data/APN and untick Data Roaming and Mobile Network? Am I missing anything else?
That'll do it, however, just unticking data roaming theoretically should be enough. Allways good to err on the side of caution though.
Cheers, mate.
Just as you said, I did think disabling data roaming on its own may be enough. I just thought I'd better safeguard myself as much as possible.
Adhering to the strict agreed standards on 'airplane mode', you shouldnt be able to.Others have mentioned this already, but android 2.0+, you can enable wifi in airplane mode.
That is not correct, may have been before carriers starting putting inflight WiFi in the planes. So having the phone allow WiFi to work while in airplane mode is not a bug. I have used in plane WiFi before for my laptop and it works well enough, I did have problems with the SIP phone though: Some lost packets and very laggy. At that time my old phone didn't support WiFi in plane mode.Adhering to the strict agreed standards on 'airplane mode', you shouldnt be able to.
Either it's a 2.x bug, or a HTC one.
