Help Airplane Mode Widget Vanished
Sometime after I added the stock HTC Airplane Mode widget to one of my home screens, the widget vanished from the screen without any intentional action on my part, and it is no longer present in the list of add-able widgets. The only thing I can think of that might have caused this is that I once tapped "Get more HTC widgets" from the "Add widget" screen.
I know that there's an Airplane Mode widget available from the Market, but I like the look of the HTC widget. Does anyone know how I can get the HTC Airplane Mode widget back? Thanks.
Welcome.
You probably deleted the widget off of the home screen by accident. I did that a couple of times, the first couple of weeks I had my phone.
In any event, the widget is there, but not in the place you're looking.
  • Click the "+" (or do a long hold in the location you want the widget)
  • Scroll down to settings. This will bring you to wireless/mobile widgets.
  • Then choose the airplane widget.
