alarm clock snooze
krellos
Hi having a problem with the snooze setting on my alarm clock. its set for 6am Mon to Fri with snooze 5 times at 10 minute intervals. this happens in the morning then the next time i go into alarm to check its set it defaults to 5 times at 3 minute intervals...which lead to me being very confused the other morning lol.
Anyone had same issue or can fix?
I've never experienced it personally but a possible solution is to go to settings, applications, manage applications, all tab, clock and then clear data. You will have to reset your alarms and alarm tones after but hopefully the settings will stop going back to default after.
I actually did that last night and also turned off the smart light thing... went in to check it and its still on 10 minutes... cross fingers it's sorted!
can't believe I've had it and been trying to fix it all this time then just as i give up all hope and see if anyone else can fix it it fixes itself!!! typical!!
