Hendrick2488
Well, after the first night it appears to work fine. If this changes I will re-post.
The ONLY 'fix' that I have found is making sure the night before, that when I put it in the dock, it shows right above the actual time in the right corner the alarm time. If that is NOT there, the alarm isn't going to go off- it knows in advance that it won't go off, even though the alarm checkbox is marked..... I have just become very anal about checking that every night, and if it is not there I uncheck and recheck the box and that seems to make the alarm time pop up there, and the alarm goes off as it should.
