Alarm issue.
sorbet
My roommate and I just got Eris' (yay!) and I can use my alarm fine, it rings and and vibrates like I want it to. However, hers doesn't make any noise, if it's supposed to vibrate and ring it'll just vibrate, if it's supposed to just ring the trackball will light up and the phone will make no noise.
We've done everything we could think of, any help?
The alarm volume is probably set to it's minimum level. Go to the alarm screen, select the alarm and select alarm sound, When you are on the screen to select the alarm sound use the volume keys to increase the volume.
You can also download an audio control app from the market- Volume Control or AudioManager for example. Most are free and provide an easy way to check and set audio level for volume, ringer, notifications, media etc
Yes, the Alarm Volume is set, while you're on the screen to pick the ringtone. So click on the ringtone for the alarm, then, before making your selection, change the Alarm volume right there, by pushing the volume buttons on the phone.
You can push cancel, if you already have the ringtone you wanted picked out.
