Help "Alarm Reset" popup??
moespeeds
Member
Anyone ever get an "Alarm Reset" popup? A few days ago I was playing sims3 and ran my battery completely dead where the phone shut off on me. When I charged it and turned it back on, I had "Alarm Reset" popup every 10 sec or so and the screen would not black out on it's own. I was running a rooted Verizon Droid X with launcher pro. I did an sbf back to .320 then up to .340 and wiped the phone, and downloaded my apps from market rather than restore with Ti. I also flashed apex using ROM manager. Problem gone. Yesterday I was playing sims again and in about 15min my phone went from 90% battery to 0% and died. Again, the "Alarm Reset" popup. It went away on it's own for a few hours, then started again last night and was still going this morning. I ran titanium and backed up all my apps and system settings with the intention of doing another wipe, but by the time Ti was done backing up, the popup had stopped. So far it's been good all day. I did a forum search and could only find one other instance in the Evo forum. So far nobody seems to know what it is. Here is the link:
http://androidforums.com/evo-4g-all-things-root/259862-need-help-alarm-reset-popup.html
Below is the log from alogcat:
I/WindowOrientationListener( 1266): setTiltFlatStatus[false]
I/WindowOrientationListener( 1266): 354, 56, 0
D/cg ( 1908): BootReceiver.java:34 app/alarm/rotatelogs/rotate
I/WindowOrientationListener( 1266): 354, 55, 0
D/dalvikvm( 1841): GC_EXPLICIT freed 2996 objects / 213784 bytes in 48ms
D/NetworkRequestUtil/ConstructEventRequestPath( 2065): /__utm.gif?utmwv=4.5ma&utmn=935016719&utmt=event&ut me=5(market_install*search*appbrain)(0)8(5!phone)9 (5!verizon%20cdma_shadow)11(5!1)&utmcs=UTF-8&utmsr=480x854&utmul=en-US&utmac=UA-7184590-8&utmcc=__utma%3D999.1434977313.1295483404.1295483 404.1295483404.1%2B__utmz%3D999.1295483404.1.1.utm csr%3Dandroidmarket%7Cutmccn%3Dsearch%7Cutmcmd%3Dd evice%7Cutmctr%3Dappbrain
W/googleanalytics( 2065): Problem with socket or streams.
W/googleanalytics( 2065): java.net.ConnectException: www.google-analytics.com/127.0.0.1:80 - Connection refused
W/googleanalytics( 2065): at org.apache.harmony.luni.net.PlainSocketImpl.connec t(PlainSocketImpl.java:254)
W/googleanalytics( 2065): at org.apache.harmony.luni.net.PlainSocketImpl.connec t(PlainSocketImpl.java:533)
W/googleanalytics( 2065): at java.net.Socket.connect(Socket.java:1055)
W/googleanalytics( 2065): at org.apache.http.conn.scheme.PlainSocketFactory.con nectSocket(PlainSocketFactory.java:119)
W/googleanalytics( 2065): at com.google.android.apps.analytics.PipelinedRequest er.maybeOpenConnection(Unknown Source)
W/googleanalytics( 2065): at com.google.android.apps.analytics.PipelinedRequest er.addRequest(Unknown Source)
W/googleanalytics( 2065): at com.google.android.apps.analytics.NetworkDispatche r$DispatcherThread$AsyncDispatchTask.dispatchSomeP endingEvents(Unknown Source)
W/googleanalytics( 2065): at com.google.android.apps.analytics.NetworkDispatche r$DispatcherThread$AsyncDispatchTask.run(Unknown Source)
W/googleanalytics( 2065): at android.os.Handler.handleCallback(Handler.java:587 )
W/googleanalytics( 2065): at android.os.Handler.dispatchMessage(Handler.java:92 )
W/googleanalytics( 2065): at android.os.Looper.loop(Looper.java:143)
W/googleanalytics( 2065): at android.os.HandlerThread.run(HandlerThread.java:60 )
D/dalvikvm( 1961): GC_EXPLICIT freed 2616 objects / 169976 bytes in 76ms
I/WindowOrientationListener( 1266): 353, 55, 0
D/dalvikvm( 2417): GC_FOR_MALLOC freed 5742 objects / 710776 bytes in 87ms
