Help Album Cover Art
So I grabbed art, but how do you get it to populate over to the Xoom music app? Right now the album covers only show within the grabber app.
Found the answer here: music player not displaying most album art, help. - Android Forums
After importing covers from the grabber, you have to go to settings/applications/manage applications and "clear data" under the music application (I was mistaken in thinking that the grabber had to be "cleared" of data). It will give you a scary message that you are going to erase EVERYTHING. But take the plunge. Then open the music application, and another scary message will appear that all your music is history. It's not. The album covers will then load in the stock music app.
I'd thank myself if I could :p
Just had my 32GB Motorola Xoom for 1 day and loving it. Thanks to the poster for curing album art.. Its a pet hate of mine not to have the album cover in my music library
Any way of doing this for movies too? I have tried copying .jpeg, .tbn into the folder but no luck... gesss I wish XBMC was on Droid... :(
