Root alittle irritating. .
okay so on my admire downloading music went straight to my SD no problems. now with the motion i download music and it takes up my phone memory it's pretty annoying. any help guys ? i just want my music to be on my SD :( and sorry for putting this in the all things root .
Thats what i do (side note i use es file explorer, its also a root explorer; a bunch of more features)
but Iwas wondering if there is any way to set the phone to download thing external storage automatically
what about downloading Music from Rhapsody ? have any of you figured out how download them to the SD ? sorry for sounding like a noob but this is the first time I've used that app
Root it, install Directory Bind..and bind your /sdcard/Downloads to /sdcard/external_sd/Downloads...
now anything you download will go to your Sd card instead
the main folders you want to bind would probably be Android and Downloads....though Music, Media, glu, and gameloft folders are also a good idea...
i freed up about 3 gigs of internal just from moving the Android folder
in advanced settings type/mnt/sdcard/external_sd/Music/Rhapsody/
Rhapsody will download to that folder from now on
