Looking for clarification!
thanks
I am talking about the wall charger.
You changed your photos after I posted my second post. LOLWell, they either come attached to the cable or they are just wall to USB dongles that use a standard USB cable to plug into your phone.
ANY power outlet to USB changer will work.
Most use micro usb interface? How about all of the american made HTC phones within the last 5 years? Do they all use the same exact wall charger from the box?No. Early ones use a MINI USB interface:
Most now use a MICRO USB interface:
I have a TON of both, so I keep several of these handy:
They are only a few bucks on Amazon.
Hope this helps!
If I recollect correctly, micro-usb has been established as the standard for all phones manufactured from 2011 forward. I believe the Iphone is the only exception.
So does that mean any micro USB charger will work fine regardless of manufacturer?
