Root All in ONE post!
faxanidu
Hi Ya'll!
just a quick FYI: Optimus L3 , Optimus Logic , LG e400
is the SAME phone!
First make sure you have the drivers for your DEVICE
Rooting Guide
To get custom recovery install Rom Manager (clockworkmod) from the market and
flash recovery for the LG Optimus L3!
DONT FLASH ANY ROMS FROM THE ROM MANAGER!!! USE THE CUSTOM RECOVERY!!!!
UPDATE 1!
Edit: Posted some links for your viewing pleasure.
So still working on the ROM bashing my head against the chalkboard! BUT I went
ahead and tweaked the kernel since it was poorly written... Go ahead and try it out!
Make sure you flash as zip in your RECOVERY MENU! Will make your phone ALOT more
snappier! (I can play final fantasy VII with NO lag now) And it now has MOAR
underclock! (122mhz) for all your power saving needs!
OVERCLOCK COMING SOON
Also i recommend using THIS!
One Power Guard
Wifi Problem............Bad Driver
No service..............Not reading SIM
APN not saving........UNKNOWN
USB.......................Fixed
New STOCK Kernel
MIUI ROM
CyanogenMod 9
CM9 E400 Source
We have a working one click root, recovery, & install Superuser. (not released yet) ROM is next. They will be hosted at androidarea51.com
