johnnyl1111
Android Expert
you want to switch to a different firmware for whatever reason but hate to go through the unbrick reroot etc.. process to do so. now you can just flash the firmware.
contains:aboot,kernel and modem
if someone can think of another partition i should add let me know
no need to wipe anything first, just flash it.
edit:contains stock kernel. if your using modified f kernel on stock for removing google books and movies etc.. then flashing one of these kernels will cause morningcall error.
if your using f aboot for loki recovery or kernel this will cause bootloop if you flash a different aboot.
all versions firmware flashable installer
ver c firmware
ver d firmware
ver e firmware
ver f firmware
ver c firmware
ver d firmware
ver e firmware
ver f firmware
