Help Allshare won't stream video/mp3s
MarkJC
I'm trying to use allshare to stream videos/musics from my PC to my Captivate. It finds my PC and all files are showing up, but when I click 'Add to Playlist' on a file, as soon as it goes to the player, I either get:
"Unsupported file type" or
"Sorry, this video cannot be played"
I'm getting these messages for every file type: wmv, avi, mp3, mp4, wav
I know the captivate supports these - if I download the files without trying to stream them, they play fine in the player. But anytime I try to stream, i'm getting those errors. Does anyone know what could be causing this or how I might fix it? (Are there any market apps that work like allshare does that I could try?)
Hi Mark, have you found any solution to this yet? I have the same issue, let me know if you get any tips or info on this. I would appreciate. i am looking for solutions as well...
No I haven't found a solution yet unfortunately. I've posted on a few other forums also but haven't had a response.
Most of my errors when I started screwing with allshare were from wmc12, not the phone, long story short, it doesn't automatically stream, and it doesn't include most of the modern formats when building libraries. Once I solved that, almost everything streams now, but allshare refuses to even try streaming an .mkv file, if you rename it to avi, it will.
I'm on win7 x64, which I've heard has difficulties, but here's what solved most of my problems.
Enabling streaming (on win 7, if you already have a home network library set up, you can go to Network, click on your media device, and when it opens in wmp, click on share, and go from there.)
installing shark007 codecs, after uninstalling my old ones
Installed the divx pack DivX Plus Codec Pack ? DivX codecs for Windows media player | DivX.com The only reason I added this, is because it changes wmc to allow mkv's in it's library. I later uninstalled it, and retained the function, but that also could have been because of shark007, I kinda threw everything at the wall hoping something would stick.
Unfortunately i'm using PS3 Media Server to stream so windows media center isn't the issue for me. I can stream fine on my PS3 from the computer, but the phone refuses to play the streaming files for some reason.
Well, im trying to view videos I take with my samsumg vibrant phone on my samsung TV via allshare and its impossible. It freezes after one second. I tried different apps and no success. Anyone???? Thanks
Marc I'm able to watch videos via allshare. Seems like after I got a software update on my phone and on my Samsung TV now am able to watch videos and they are HD quality. Awesome!!!
That's great, i'm glad it's working for you. Which software update was it that you used? Was it the AT&T update through settings?
I know,and its awesome HD quality. I have the samsumg vibrant so I got the update from T-Mobile. I also checked for new update on my TV and found one. Not sure what did the trick but its working now.
